Blinking control panel rinse cycle
The top panel is all off but the RINSE button is blinking. When you hit the cancel button 2 dashes apear and then disapear when hit again. If the door is closed real hard it might stat to run or run for half the cycle and then stop. I have power to the unit ans I assume the internal fuse #6 is not blown. I guess that I am trying to confirm that replacing the Control Panel #11 is the right move.
Mr Howdy
I have a similar problem. Did you fix it?
I had the same problem Mr. Howdy..
Than I found someone on here that told me what to do and it worked.
Hopefully what i a gonna tell ya will work also.
I pressed cancel than opened the door. within 3 seconds.
I hit the HIgh temp scrub than the energy saver than repeat it again. If it does work all the lights will light up . close the door and the rinse light should go off..
Good luck this site is great for helping people out…let me know if this works.
Julie
