Black gunk accumulating
Black gunk which resembles mold but bleach will not remove is accumulating on the gray rubbet gasket attached between the washer housing and drum. Tried acetone, OOPS, bleach and scraping. It’s still there
Replacement parts for MAYTAG MAH6500AWW | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Here is a tech bulletin
http://www.servicematters.com/maytag_library/docs/TDL-0051A-B.pdf
See the following discussion about mold etc. is for a Whirlpool but much of it will apply to your unit.
http://forum.appliancepartspros.com/washer-repair/1807-whirlpool-washer-smells-moldy-whenever-idle.html
Just more info
http://www.applianceaid.com/neptune.html
Just Google “neptune mold” and you will see how common this problem is. Many people just leave the door partially open when not using the unit.
Also it is very important to use the recommended soap.
