Can the drive belt on the Maytag MAH2400AWW front load washer be replace from the front of the machine?
I replaced the belt on a front-load Kenmore by removing the back panel. I would assume front-load machines have similar construction. I used instructions for replacing a belt on a GE washer which worked. I hope this link is helpful to you as well. Good luck!
GE HydroWave Washer Belt Replacement
