Belt replacement help
Replacing the belt on my WW electric dryer. Was able to get the old belt out pretty easily thru the panel on the back at the motor, it was broken so it came out pretty easy.
Picking up a new belt today and have a diagram for the belt path when its completed.
Question Id appreciate some help on is what direction should I go at this thing to put on the new belt? From the front or the underside of the machine?
Im a compitent tinkerer but have never worked on a dryer before, any help would be appreciated
Take Care
You have to remove the front panel to put the new belt around the drum. The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE MDE546REW0 Frg(v4) / Electric Dryer | AppliancePartsPros.com
Dryer disassemble procedure.pdf (34.5 KB)
Frigidaire dryer belt configuration.pdf (36.3 KB)
