[SIZE=5][COLOR=Black][B]Toxic Smoke…took days to clear from the house. No Flames..plenty of hot spots around the lower left side cabinets.
Cleaned the inside rear filter, but I don’t think that is the reason.
I suspect it’s a motor problem, but not sure.
Should this dishwasher be thrown away. It runs and does not leak.
I feel very unsafe with electrical power to this unit…I’m having to wash dishes , the old fashioned way…and I thought I was a big shot…not a dishwasher ! [/B][/COLOR][/SIZE]
I could not find any tech info on the given model number.
If it is a non USA model I probably will not be able to.
If you cannot find the what and the why it overheated and be able to fix it properly, I would scrap it.
I think Beaumark is actually a GE but am not sure.
Try to contact them or search to see if this unit is part of a recall.
There have been several recalls over the years covering lots of different manufacture’s units with overheating/electrical problems.
[QUOTE=denman;474677]I could not find any tech info on the given model number.
There have been several recalls over the years covering lots of different manufacture’s units with overheating/electrical problems.[/QUOTE]
[COLOR=Black]Thank you denman…I needed some guidance. Sounds like good advice.[/COLOR]
