balance ring
Where is the balance ring located on this HE top loading model? Thanks.
It’s part of the spin basket, under the tub ring. If you lift the whole deck the tub ring unclips from the tub and exposes the top of the basket, that plastic top edge is it. Not a separate part #.
Why do you want to replace balance ring?
