Baking element replaced but still not working
I replaced the baking element in my oven recently but it still doesn’t work. The broiler works and so does all the cooking elements on the top of the range. What can possibly be the problem? Thanks Linda
Replacement parts for FRIGIDAIRE FEF322WHSA | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316002602.pdf
I would say that the The selector switch is the most likely culprit. Item 13 in Section 1 since the broil element work and I assume that the thermostat does control it. Could also be that a wire has burned off.
One way to check it would be to unplug the unit.
Set it to bake and check the continuity of the switch.
Contacts 1 to 3 should be 0 ohms.
If OK
Check the wires going to the element.
