Brand: Samsung Model Number: NE59M4310SS/AA Main Symptom: Oven will not heat to temp What happens & when: Went to replace element and element had melted to metal pan below, can this pan be replaced/repaired and how does this part get removed
Error Code (if any): N/A
Parts or tests already tried: N/A
Photos / video link: Do not have photos
Yes, this pan can be replaced. The part number is DG63-00065D.
To remove the old pan, there should be 2–4 screws holding it in place—typically two in the front and two in the back. I believe the screws are either Phillips-head or 1/4-inch hex-head screws.
Once the screws are removed, the pan should come off
Yes, remove the bottom drawer and you should be able to access it from there. Once the drawer is out, you should have a better view of the area and be able to reach the necessary screws or components.
