Brand:Samsung
Model Number:NE58F9500ss
Main Symptom: Oven does not reach temperature
What happens & when: when on bake the oven loses power to bake element and hear clicking noise on control board. Is there any other part that would shut off the bake cycle?
Error Code (if any): None
Parts or tests already tried: voltage and continuity on the elements and control board; replaced temp probe; voltage lost in both regular bake and convection bake
What voltage are you reading at the bake element when it should be heating?
Voltage show 240 and when relay opens(the clicking noise) it drops to zero.
Does broil work or do the same thing?
No. The broil setting maintains 240 volts.
With broil working and continuity on the bake element that sounds like a bad main control DE92-02439G to me.
https://www.appliancepartspros.com/samsung-assy-pcb-main-de92-02439g-ap5800583.html
Ok, that is what I was thinking but I wanted to make sure there was not some other sensor that might be bad and cutting it off.
