Avanti WCR683DZD
This is a dual zone wine fridge. I am replacing all 3 fans in the unit. One is loud (on top) and the one in the middle (in the tray) is not working. The small lower (heater from what I Can tell) one is fine.
I did find AP5180373 & AP5180379 and will be ordering them.
http://www.avantiproducts.com/parts/wcr683dzd_exploded_view_and_parts_list_led_version.pdf
I have two questions
My issue
For the middle fan and lower have the same plug and I did not notice the wiring. I may have flipped flopped the plugs.
  1. The wiring diagram shows the color as black/red for both. But, the connectors are white/red and yellow/red. The white/red turns on the fan every min or two. I am guessing that this is for the middle fan??? The other yellow/red I have not seen turn on a fan (heater)??
  2. What is the air flow. It looks like the top fan intake is from the top section and blows down on the evap. Then the middle fan intake is from the lower of the top section and channels to the middle back of the unit?
like
AIR Flow --TOP Fan---->>
  AIR Flow
   V
Middle FAN---->>
LOWER FAN <—Air
If you can help me understand the airflow this can help me confirm the wiring and the fan direction when I get the new fans.
I have an Avanti Wine Chiller with a bad Control Panel
Model # WCR683DZD-2
Mfg Part # Z-DG13-1013
I would like to purchase the control panel.
Do you have it? or do you know where I can get one?
email address
[email removed]
