How to remove wire connections from old latch assy and attch to new latch assy. ?
Here are the parts
Replacement parts for MAYTAG MDB7600AWW | AppliancePartsPros.com
The wires should pull off the switch’s studs.
Often they are very tight.
Sometimes grabbing the connector with a pair of needle nose pliers and wiggling it side to side while pulling will get them off.
Sometimes using a flat blade screwdiver on the solid side of the connector and prying between it and the switch body will work.
Also remember to mark the wires so you know where they reattach.
I have installed the new latch assy. Thanks for the assist.
we supply original and retro air jordan shoes,and ********** air force ones** and jordan fusion shoes,and also you pick your cheap jordanson our cheap jordan online store.
