:eek: magic chef model # DU2500V ; when I start the unit it fills with some water in bottom of unit , then it pumps what little water out ? the arm spray not spinning / no water spray at all ( runs cycle with very little water leaving unclean dishes ) ??? thank you for your time
Robert H.
Replacement parts for MAGIC CHEF DU2500V Dishwasher - Undercounter | AppliancePartsPros.com
The most common cause of a low water fill is a partially clogged screen filter on the inlet side of the water valve.
Remove the valve and clean/check the screen.
Do not remove the screen as it is there to keep crud out of the valve which could hold the valve open and cause a flood.
