Brand: Maytag
Model Number: LAT8624AAE
Main Symptom: Timer Bad
What happens & when: Won’t complete cycles
Brand: Maytag
If the connections seem stiff work them back and forth while pulling to get them off of the terminals, if there are locking tabs make sure they are being depressed.
Thank you. I worked them and worked them, but I finally did it. It helped when I realized that there was only 1 locking clip on each side. Now, I’m researching if it’s ok that the timer is on Presoak. l just got it all put back together, but the position of the timer is on the beginning of my Normal Cycle. I think it’s supposed to be at the top. This is all new to me. I’m trying though.
