Americana Refrigerator Freezes Everything
It freezes everything, even with the control setting on “0”
The model number you posted is incomplete. Verify and repost it please.
[quote=Gene;739670]The model number you posted is incomplete. Verify and repost it please.
Gene.[/quote]Thanks Gene, The Model # A3309AASAWW, hope this helps.
Try to adjust the air diffuser in the freezer so, most of cold air will be directed into the freezer.
If it would not help, replace the cold control.
Gene, I am so greatful for your willing to help me, I will gladly use your advise but,could you please tell me where the air diffuser is located. I am
lost as a Christmas Turkey on the 4th of July!!!
It’s mounted to the evaporator assembly cover (inside the freezer) and is shown as #307 at the diagram.
