Brand:Amana
Model Number:AFD2534DEW
Main Symptom: New circuit board install can’t enter code
What happens & when: Due to frost build up I have replaced the heater element, heater thermostat with no change. I replaced the circuit board just now and the procedure for entering the code isn’t working. There are French doors so I can’t hold down a single light switch and push the freezer down button. Do I close one door and hold down the other light switch? It doen’t seem to be working. When I plug in the unit it’s running. Is that normal without programming the new circuit board?
