Brand: AMANA Model Number: NTW4605EW0 Main Symptom: TRYING TO UNLOCK LID LOCK MECHANISM What happens & when: REPLACED THE LID LOCKING MECHANISM IN THE WASHER, TRYING TO RUN A DIAGNOSTIC MODE TO GET THE LID LOCKING MECHANISM OUT OF “LOCK MODE” BUT THE “LID LOCK” RED LIGHT KEEPS BLINKING, HOW DO I GET THE RED LID LOCK LIGHT TO STOP BLINKING?
Error Code (if any): RIGHT LID LOCK LIGHT BLINKING
Parts or tests already tried: INSTALLED NEW LID LOCK MECHANISM YESTERDAY, THE MECHANISM IS IN THE “LOCK” POSITION, TRIED TO RUN DIAGNOSTIC MODE BUT THE RED BLINKING LIGHT FOR LID LOCK ON THE WASH WILL NOT GO AWAY
If you unplug the washer for a couple minutes and plug it back in, does the light immediately start flashing? If it doesn’t, try going into diagnostic mode.
Yes, the red lid locking light comes right on. Originally we had to change out the lid locking mechanism, which we just put in the new part yesterday, then we tried to run a diagnostic run, because the part we got the from you guys came in the “lock position” and the lid wont close all the way because of it, so I called customer service and they said to try diagnostic mode, which it wont even go into because of the lid locking light
It just stopped working. The washer would fill up half way, then it wouldnt run the cycle. Then I would unplug the washer to reset and then the lock wouldnt unlock to let me open the lid
With the original lock issues this sounds like an issue with the control board W11116498, it is possible that it is a bad lock out of the box but these lock assemblies come in the locked position quite often and get unlocked when the board first powers up.
If you disconnect the lock at the board and power it up does that lid lock light begin to flash when the unit is plugged back in? You might be able to get into diagnostics mode that way if it doesn’t.
