Amana washer will not drain
Brand: Amana
Model Number: NTW4705EW0
Main Symptom: My washer is full of water and it will not drain. The tub stays full of water. All I hear is a noise but it won’t drain. I ran a load tonight and all the sudden it isn’t draining.
That sounds like you’ve either got a clog in the drain system or the drain pump WPW10661045 has failed.
https://www.appliancepartspros.com/whirlpool-pump-water-wpw10661045-ap6023670.html
