I have an amana model NTW4516FW. It spins extremely load like a flying airplane. Please advice how to resolve. Thanks
That kind of noise is usually due to the bearings wearing out. Not really expensive in terms of parts but a lot of labor. If the machine is quite old you should consider replacement. My idea of repair to older washers is for the unit to go to washer heaven !!!
Wilsonjiaho, this is certainly going to be a bearing failure. However, the bearing is only available as a part of the gearcase W11454741.
