From your previous posts I believe that I need to replace the water inlet valve (water slowly fills after it is shut off) where will I find the valve and how do I get to it on my model? I have found the part on your web site and will purchase once I have tried to unplug and see if it stops before I buy the part. Thanks, Sandy
If you will loosen the screws at the bottom of the front panel, and insert a screw driver or stiff putty knife in the gap between the top and front near the edges you can release the clips that hold the front panel on and lift it off.
You can now take out the two screws that hold the top to the cabinet and it will flip up. This will give you access to the mixing valve to replace it.
Good luck, hope this helps.
