Hi, I have a amana washer info listed above. No matter what the load is or how many times it has been re adjusted, it walks and vibrates across the floor. The only thing I can see is that the springs seem a bit loose and when moving the tub, it doesn’t always return to center. Everything else seems in good shape. Yes, the machine is level and on a solid floor. Any input would be appreciated.
Tough to diagnose because something can be broken in the support system yet not visible.
I would start by replacing the springs.
Here is a service manual which may help.
http://www.servicematters.com/maytag_library/docs/16022937.pdf
Thank you for the reply, I pulled out all 7 springs and the tension seems good. After re-installing the springs the balance seems better for the most part. I will be keeping my eyes on it for awhile and see if the wobble gets any worse.
Ok, good. Springs can be bad but look ok, so if it does not stay well I would replace them.
Thanks for the update. Good luck.
