Amana Wall Oven
Our Amana wall oven, model AOCS3040E has not been working properly. It seems to take a long time to preheat and then will not hold the set temperature even though the screen says it is still at that temp. For instance if I hit bake again as if to set a new temp, it will start to preheat again showing actual temp at 70-80 deg below previously set temp. It also will just cut off sometimes when baking for a length of time, as though it lost power. The screen will go blank and then after a few seconds come back on with the time blinking. I figure it must be ERC or relay board? Thanks for any help.
Hi Jeff,
More likely the problem is a bad relay board, but there is a small chance for the ERC to be bad as well.
You may want to order both parts from Appliance Parts Pros and replace the relay board first.
Due to very friendly Appliance Parts Pros return policy you can return any unneeded part even if it was installed.
Here are the breakdown diagrams and Replacement parts for AMANA AOCS3040E Walloven - Std Ele | AppliancePartsPros.com
Thanks for the help Gene. Sounds like a good plan.
Jeff
You are welcome Jeff. Keep us posted.
