Amana starts itself and makes loud noise
Brand:Amana
**Model Number:**ntw4519jw2
Main Symptom: Starts automatically, makes strange noise,
What happens & when: Starts strange noise upon power up.
Error Code (if any):F3E1 Pressure System Fault
Parts or tests already tried: N/A
Photos / video link:https://m.youtube.com/watch?v=bwPzb5qzt8I
It starts making weird noises right after its plugged into the wall socket. I didn’t even touch anything.
It reminds me of flood mode?
This noise keeps going and sometimes if i press start it will fill water into machine and complete some weird cycle but once it finished it just starts over again.
I got into diagnostics mode and it started to make that noise randomly even thought I did not start any tests.
Anyway auto diag test seemed ok? you can see it in the video
Also the error code was F3E1 Pressure System Fault. Is this noise related to F3E1 fault?
Junky washer for sure! Don’t know about the noise over the Internet,but washer more than likely has a bad control board,Read this service pointer here! W11766193.
It sounds like the drain pump is operating while empty. If you remove the back panel of the console and disconnect the pressure hose from the control, does it continue? If it does, the main control has failed. W11607637 Electronic Control Board (Main Control) | Genuine Whirlpool OEM In Stock
you saved me 300 dollars. thank you so much!! they replaced the board for free in the end after some hassle with an unnecessary warranty.
