My Amana fridge (bottom freezer) is always running. The evaporator fan in the freezer is always running as well, and the evaporator coils are not frosted over. Freezer and fridge both feel good and cold but I haven’t taken a temperature reading.
The evap coils have a very thin frosting on them, but not really noticeable unless you put your head in the freezer and get in close.
Ill measure the temps here shortly and post them up.
I did notice that the cover on the lower back part of the fridge is missing. I think it deteriorated over time and eventually fell apart. Is it possible that this is causing the problem?
[QUOTE=acteg;354328]…I did notice that the cover on the lower back part of the fridge is missing… Is it possible that this is causing the problem?..[/QUOTE]
Yes, it is possible because it is affecting the cooling air flow in the compressor compartment.
This cover is no longer available but you make it from a piece of cardboard. Look at the cover shown on the diagram and use it as a sample.
