amana ref. no water
:eek: When we push the water button in the refrigerator no water comes out. Pump makes a noise but no water. There appears to be water at the filter.
How old is the filter?
If it’s more then a year old - most likely the problem is a clog in the filter.
  • The part number for the water filter is AP4260337
thanks for your quick response Gene, had filter removed and still no water coming. Is that normal?? Will try replacing the filter. Thanks.
If you have the filter removed, you have to use a filter bypass (special part). Otherwise there would not be any water flow at all.
Thanks again I will try the filter;unk. age of filter ,we just moved in recently. Thanks again.
Keep me updated, please.
good morning. I need your help please I just change the igniter because the old one did not glow at all the new one glows but the burner do not get flames, but its passing gas if I put a match get the flame. what it can be please i need your help please.
thanks. martha:confused:
You probably installed the new igniter in the wrong position.
I need the complete model number of the range and the picture of the burner with the new igniter (if possible).
