I have this Mv that started acting up today. Display operates normally. You set the cook time and it starts and runs but turns off after 3 seconds. There is a ticking type noise while it runs that is new also. Can anyone point me in a direction ?
Hello,
What happens with the display when it turns off by itself?
Here are the breakdown diagrams and Parts for Maytag AMV1160VAS2 Microwave - AppliancePartsPros.com
The display is fine. It counts down and returns to normal. There is a funny noise though from the right side. Not the usual sound it made
So, how did you know it was shut off?
If you set the timer for 2 minutes it starts and runs but the cycle stops after 3 seconds. The inside light turns off and the timer returns to normal and it beeps twice.
Try to run the microwave with the control panel open. If it will run as usual then the magnetron has gone bad.
- The magnetron AP5982291
What do you mean by “control panel open”?
Unplug the microwave. Remove the screws located in front on top of the microwave securing the grille. Pull outward on the top portion of the grille releasing the tabs. Remove the screw located at the top of the touch panel. Pull the top of the touch panel toward yourself but do not release the bottom tabs. Now the control panel is open for about 30°.
Do not touch anything behind the control panel. Plug the microwave back. Reset the clock and try to run it.
I did as suggested. Loosened control panel and tried to run cycle. Does the same thing, starts /runs / stops at 3 sec. There is a noticeable ticking coming from the area above the control panel on the right as it runs.
Sounds like there are two bad parts: the magnetron and the control board. The part number for the magnetron I posted earlier.
- The control board AP6017241
You have to remove the microwave from the cabinet to access the magnetron.
UPDATE: the ticking noise when running is coming from the board on the control panel. Any ideas??
Appears to be Omron 24VDC relay on control board. Ideas?
So, the new control board should fix it. Hopefully the magnetron is still good because my suggestion about it was based on the noise from the above of the control panel. The magnetron is sitting there.
Yeah I figured the board was bad. The sound seemed to come from the back but I pulled the unit and powered it with the cover removed. I could feel the relay making noise. Also checked diode while it was apart. Thanks for your help.
Happy holidays!
Happy Holidays to you as well!
Keep us posted.
Back to square one again! I replaced the control board and no luck. Still shuts off after 3 sec. What to do now?
Sorry to hear it.
Does it make the same noise too? Does the fan work?
Yeah same noise from relay on the board. Fan works also. I have checked door switches, diode, thermal cut switch, ohmed the magnetron. Need new ideas.
Very strange situation. Try to replace the magnetron. If it would not fix the problem then you can return it.
