Brand: Amana
Model Number: NTW4516FW3
Main Symptom: Grinding noise w/no Agitation
Amana NTW4516FW3 Inner Spin Base removal – I had diagnosed the griding/clicking w/out agitation down to the Splutch Pulley. The Inner gear was chewed up. The Transmission input fiber shaft also had slight wear also on lower half of the shaft.
I installed a new Splutch Pully however the noise remains. A new transmission has been acquired & will be replaced;
My issue is removing the Inner Spin Base so I can replace the transmission. The Spanner Nut is removed, and penetrating oil has been used for several days along the Tub & Drive Block.
I have been using a dead blow hammer on the Inner Spin Base trying to loosen & break it free. What else can I do to release the Inner Spin Base from the transmission output shaft w/out damage to Tub or other parts?
Error Code (if any): n/a
Parts or tests already tried: Splutch Pully
Thanks Brian
Model: NTW4516FW3
Before we move on to diagnosis and repair tips, I need a few points of clarification:
The clicking sound you hear without any agitation—does it occur during the wash cycle, spin cycle, or both?
Are you trying to remove the inner spin basket?
- If so, is the problem that the basket is stuck and will not separate from the drive block?
Please let us know, and we’ll be happy to help you complete your repair.
1: The clicking occurs in the wash cycle. I didn’t switch to spin to verify that. A visual of the Splutch Pully (inside gear) along with the transmission input shaft reflected it occurs in the agitation vs spin mode.
2: I am attempting to remove the inner spin basket and it will not separate from the drive block. I am hesitant to apply too much force & damage other items.
Thanks, Brian P.
Have you checked the condition of the agitator dogs?
Sometimes the inner basket hub with “weld” itself to the drive hub due to the corrosive effects of water, detergents and bleach. There are a couple of ways to strike the drive block while pulling up on the spin basket to free it
- Thread the spanner nut a few turns down on the drive hub to protect the threads. While pulling up on the outer edge of the spin basket strike the spanner nut a couple of times to break the corrosion and build up loose. You may have to hit it pretty hard.
- Find a short length of pipe that fits over the output shaft and rests on the top of the drive block. While pulling up on the spin basket strike the pipe and try to drive the drive block down
