Amana NED7200 TW
It suddenly stop producing hot air. What do I do?
Parts for Maytag NED7200TW10 Dryer - AppliancePartsPros.com
Since the heater runs off of the 240 and everything else runs off of 120 the first thing to do is check your power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
If you have 240 then unplug the unit and check the heating coil, hi-limit thermostat and the thermal cut-off for resistance.
Note : If the cut-off is open then there are other tests you should do before replacing it.
If the above parts are OK then check the thermistor for resistance.
If it is OK unplug the wires for the heater relay contacts and check across the contacts. Should be infinite ohms (open). If closed you may have to replace the board as the relay contacts are welded together. You may be able to just replace the heater relay if you have a little electronics soldering experience and can find the relay.
If the relay checks out OK then you have two possible causes.
  1. The control board is shot and is keeping the heater relay closed.
  2. The motor’s centrifugal switch for the motor is not closing. Check that the motor is clean. One way to confirm a bad switch is to short the wires to the switch together. Plug the unit in and give it a try. Just be sure that the wires cannot short to anything else (tape them) and that they cannot get caught by a moving part.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
NED7200.pdf (1.7 MB)
