Amana NED 4600YQ1 issue?!
Brand: Amana
Model Number:NED4600YQ1
Main Symptom: Activating with turn of timer knob
What happens & when: The dryer auto starts when I turned the timer knob to any of the five timed settings, but it does stop at the end of each timed period.
Error Code (if any): 0
Parts or tests already tried: I have replaced the timer, door switch, heating element, cycling thermostat, and the dryer hi-limit thermostat.
You’ll need to replace the start switch WPW10420741.
https://www.appliancepartspros.com/whirlpool-pts-switch-twist-wpw10420741-ap6021228.html
I have unfortunately replaced that part, but still the issue persists. Interestingly enough, I was finishing a load of clothes and I opened the door whilst the dryer was on the automatic dry low heat setting and the dryer properly deactivated. I was then able to close the door and choose a different setting (high heat) and pressed the push-to-start button and it worked. But, after that load was finished the problem came back. Do you think it’s a wire short?
The only other thing that can cause this is a short in the motor 279827.
https://www.appliancepartspros.com/whirlpool-dryer-drive-motor-279827-ap3094245.html
