water leaks onto floor. drip tray is always dry. also, fan is very loud.
plugged? how can i fix?
thanks!
thanks!
Hi.
Can you please explain more detailed what is the problem.
Is the temperature OK?
Thank you.
Simon.
turns out drain hole was iced over. i thawed it out and it works. is there anything i can put in the drain plug to keep it from freezing?
