I started to use an amana refridge in the kitchen which had been in the basement and the ice/water hookup wasn’t hooked up.
I replaced the first water valve as well as the post filter valve. Water through the door works fine.
After I replaced the valve, it made two trays of ice but hasn’t made any since. The icemaker unoit cycles–the forks rotate however the trays don’t fill with water.
If you manually fill the tray with water does the ice maker at least complete and eject that tray of ice cubes?
Check your freezer temperature it should be between 0 and 5 degrees F.
With a ice maker it is better to be close to the zero.
The ice makes is dependent on freezer temperature.
The ice makes is dependent on freezer temperature.[/quote]
Thanks.
I set the freezer at the coldest temp this morning and no water in the ice maker.
The model number is ARS 9167AS-
I did manually fill the trays and it worked-the makers rotates.
