This part is not an exact match. The connector is slightly larger and I am concerned about insulating the connector so as to avoid problems. The part works fine. This is the old connector:
And this is the new connector:
The concern is how close the bare connector is to the the metal housing. Since the burner floats (has movement) I would like to insulate in some way so that the bare connector cannot touch the metal housing.
What do you use that will withstand the heat that will exist when the glass top is put back on?
Or is this completely the wrong part?
Thanks.
Shawn Slater
