Amana front loader no rinse cycle
got a front loader amana washer mod # nfw7200tw,does not go into the rinse cycle,after 19 min on timer,and the lite is lit for rinse on the display. you can hear a humming noise followed by some clicking noise, this will go on for a while, the 19 still remains showing during all this, after awhile it will flash nd on the display then i turn it off.. doesn’t want to play no more:( yes the water does not drain either, i have unpluged the power for awhile seeing if the would reset something,nothing changed, im hoping for a simple fix, thanks
On the inside of the back panel there should be a tech sheet that will show you how to put it into test mode. Focus on the control unit and motor control unit.
thanks, ill check it out after work
ok found tech info book, seems things where look good but when diagnostic codes i got a few 1,10,15,22, now the whole thing dosnt work, b4 it would fill and wash, but then wouldnt drain, which the nd displayed which was water level problem, also too i notice the selector knob was really wobbly like, so i may just call in repair man,to see what the cost would be , if to much just get a new one (not a amanda) will need to look into a good brand if there is such a thing..
well had the repair guy come over .. there was a quarter stuck in the pump:confused: got the p/n for a new pump easy to replace myself (one of the vanes on the pump was broken still works till i get the new one ,
