Amana dual burner replacement not working
Brand: Amana
Model Number:AK2T30W2 P1143703N W
Main Symptom: New Part W10823726 not working
What happens & when: Replaced dual burner
Has 5 wires (2 blue, 1 brown, 1 red, & 1 Purple). 2 Blue are attached to the posts on the outer ring of the burner. The Brown is attached to the post closest to the 2 Blue wires. The Red is attached to the side with the two posts and is closest to the burner. The Purple wire is beside the Red wire and attached on the post furthest away for the burner. This is similar to the original way that the dual burner was wired, but with one exception. The original burner had a third wire on the burner ring that had a jumper wire pluged into the side of the box next to the Brown wire. Neither of the dual burners work. Do I have it wired wrong? Is it the wrong part? Any help is appreciated.
These are the instructions for # W10823726
InstructionSheet-W10863719-RevA.pdf (706.2 KB)
