Replaced thermal fuse 2 months ago. Same problem again. Received new part and installed. Won’t run…Metered all parts on heating element board..all o.k. Can’t find any disconnected wires, breaker is good, all pluged in…stumped
John Van
John Van
I cannot find a wiring diagram for this unit so can olny give general info.
[COLOR=“Blue”]Won’t run…[/COLOR]
I am assuming that the motor will not start.
[COLOR=“Blue”]Metered all parts on heating element board..all o.k.[/COLOR]
The only device in the heating area that will stop the motor from running is the thermal fuse usually mounted on the blower assembly.
Have you tried flipping the breaker off/on a couple times. Sometimes you can loose half the line or Neutral without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
Other things to check would be the door switch and the push-to-start switch.
When you replaced it did you clean/check the vent system and the blower wheel.
Something cause it to go a second time.
If yes then it could be your motor was going south, running slower and the lower air flow blew the thermal fuse. Perhaps it has finally given up the ghost.
