The “heated dry” display light comes on and we can’t turn it off. We never use “heated dry” cycle.
Can you post the whole model number off your dishwasher, it’s located on a tag on the frame when you open the door.
Nat
It’s ADB2200AWW
Try to run a diagnostic…
[FONT=Helvetica][SIZE=1][COLOR=#1b1b1b][FONT=Helvetica][SIZE=1][COLOR=#1b1b1b][FONT=Helvetica][SIZE=1][COLOR=#1b1b1b][LEFT]A Field Service Test may be started by pressing the key 5 times
followed by the key within 6 seconds. This test must be performed with
clean water to insure proper sensor performance.
“88” will appear in the display (if available*)
Try this and post what your display reads
Nat[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]
What do you mean by “key”?
The button is the key.
nat
