[quote=dionnegallagher;300977]Joe,
I just ordered these two parts based on your suggestions and I want to know if you have instructions on how to install these parts. My husband and I are both pretty handy and can probably figure it out. Plus, we’ve already had 2 repair people out to the house who basically did nothing, didn’t listen to us about the actual problem, charged us $200 and told us we “might” need a new control panel which has been discontinued. This stove is only 6 years old and the burners still work fine. The oven and control panel shut off when it gets up to temp and then won’t turn back on until it cools off. Thus, we want to try replacing the parts that you suggested prior to forking out $2500 for a new slide in range. Thanks!
Dionne[/quote]
Dionne,
You didn’t mention a model number, so I assume your unit is the same as Jeff’s.
First thing you’re going to do is remove power to the unit.
As I mentioned in the previous post, both limiters are located on the left side of the burner box, under the cook top.
I reccomend you replace both parts, as long as you’re there, and you can test the fan with a 120 volt test cord.
I’ve attached excerpts from a service manual, that will make it a little easier for you to procede.
Good Luck,
[LEFT][FONT=Arial]Maintop Removal–Slide-In[/FONT][/LEFT]
[LEFT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]1. Turn off electrical power and gas to the range.[/SIZE][/FONT]
[SIZE=2][FONT=Arial]2. Disconnect gas and power from unit.[/FONT][/SIZE]
[SIZE=2][FONT=Arial]3. Remove screws securing top surface burners.[/FONT][/SIZE]
[SIZE=2][FONT=Arial]4. Remove surface burner and disconnect spark ignitor[/FONT][/SIZE]
[SIZE=2][FONT=Arial]wire from surface burner.[/FONT][/SIZE][/LEFT]
[SIZE=2][FONT=Arial]5. Raise and remove maintop from unit[/FONT][/SIZE]
[LEFT][SIZE=2][FONT=Arial][FONT=Arial]ERC Cooling Fan–Slide-In[/FONT][/FONT][/SIZE][FONT=Arial][/LEFT]
[LEFT][SIZE=2][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]1. See “Maintop Removal–Slide-In” for removal.[/SIZE][/FONT]
[SIZE=2][FONT=Arial]2. Disconnect wire terminals from fan motor.[/FONT][/SIZE]
[SIZE=2][FONT=Arial]3. Remove screws securing cooling fan bracket.[/FONT][/SIZE][/LEFT]
[SIZE=2][FONT=Arial]4. Replace and reassemble in reverse order.[/FONT][/SIZE]
[LEFT][SIZE=2][FONT=Arial][FONT=Arial]Oven High Limit/Thermal Fan Switch–[/FONT][/FONT][/SIZE][FONT=Arial]
[SIZE=2][FONT=Arial]Slide-In[/FONT][/SIZE][/LEFT]
[SIZE=2][FONT=Arial]2. Disconnect wire terminals from limiter.[/FONT][/SIZE]
[SIZE=2][FONT=Arial]3. Remove screws securing limiter.[/FONT][/SIZE][/LEFT]
[SIZE=2][FONT=Arial]4. Replace and reassemble in reverse order[/FONT][/SIZE]
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]
