Amana 5.1 Cubic Big Oven need doorglass
Black Oven; the door glass broke into a million pieces. Amana no longer makes the doorglass. It was part number AP175055 in Black. Amana has a newer oven that is 5 cubic foot, but they don’t make the glass for that door either. I found the part on all the search sites but it’s on backorder. I called Amana and they said the part is discontinued.
Where can I find the doorglass that will fit or a whole new door that will fit? Help, I am trying to sell my house and don’t want to replace the whole oven. It’s just the outer piece of glass.
Thanks,
The only way is to find somebody who is going to get rid of exactly the same range with the door glass not broken - almost not possible. Try the Craigslist.
Gene,
I found the glass now can you please supply me with the instructions on how to install it?
thanks so much!!!
Hey Gene,
the oven model number is acf3335ab Amana Big Oven 1.5 cubic
the glass door part number is 31946701B
please show me instructions how to install the glass,
thanks again:D
This should help
http://www.servicematters.com/maytag_library/docs/S231_5R0.pdf
You may also want to check this to make sure yours is not deformed
http://www.servicematters.com/maytag_library/docs/CBA-307-B.pdf
Our oven glass broke as well, where did you find it at?
Where did you find the glass
