We had a power outage at our complex. The power was restored a few hours later and now all of the lights on the front panel of Jetclean EQ are lit up and flashing constantly. Any suggestions? ![]()
I saw on another post that had a similar problem that if you press & hold the drain/off button for 3 seconds, it would reset the control panel. I pressed and held it for 5 seconds for good measure and it reset and turned the unit off. I tested the function by running the unit through the rinse cycle and it appears to be running fine. Will update if there are any further issues. ![]()
