All LEDs out, only the start switch works
I have this dishwasher, it looks fairly well-kept. Washes well, but only the start switch works, the rest don’t. There is a delay switch, several wash cycle switches, a cancel and drain switch, etc. There are several LEDs on the front control panel, and none of them work. And the switches that would cause them to lite up don’t work as well.
I reseated the ribbon cable connector to the controller board, same symptom. The controller board costs $225 at AppliancePartsPros.com, so I’m hoping for a common problem, maybe an open ground? It could be the flex circuit, but an open ground is the only thing that could cause all the switches to stop working.
The Normal Wash switch works. The LED behind it does not.
Any ideas would be great. Thanks!
I have a KitchenAid dishwasher KUDL03iTSS. It got a little flaky then quit.
Last known flakyness was dryer LED was indicated but unit had not drained. Now, no LEDs are lit. Has power to unit. Checked at two places.
[QUOTE=chuckiejones;878583]I have a KitchenAid dishwasher KUDL03iTSS. It got a little flaky then quit.
Last known flakyness was dryer LED was indicated but unit had not drained. Now, no LEDs are lit. Has power to unit. Checked at two places.[/QUOTE]
I reset the 14 pin connector a couple of times. Still no LEDs.
I pushed start and the system appears to be working normally.
Hope this can help others.
