Ajust pressure regulator for LP gas
I’m trying to convert my GE Cooktop Model JGP328WEK2WW to use LP gas. I ordered a pressure regulator and LP orifices. I have installed the orifices, but when I attempted to adjust the pressure regulator (part number AP4346295) for LP gas the spring retainer didn’t look anything like the image in the installation manual. According to the manual, I need to remove the spring retainer which has a NAT end and an LP end and re-insert it with the LP in facing the unit. In the pressure regulator I purchased there are two springs, a larger diameter on held in place by a threaded plastic collar and a second smaller-shorter spring in the center of the first that is connected at one end to the inside of the regulator. I have verified with customer service that I have the correct pressure regulator so, how do I adjust it for LP Gas?
I submitted this question 12/10 per instructions from the “live chat” representative. I was told today that I needed to re-submit to get this to the top of the question list. Can someone answer this question? Thanks.
There has been no response to my question for some time. Is it unclear what I’m asking? Let me know and I’ll re-frame the question.
