Agitator removal
What is the correct procedure to remove the agitator?
Usually if can get your fingers under it and pull up it should pop off. If you can’t get your fingers under it then try using a belt or a strap to slide under and around the agitator and pull up with that. That has always worked for me. Good luck.
