Agitation Problem
My washer appears to function properly, with the exception of the agitator. It appears that the agitator dogs have worn down and are not grabbing when the unit spins. I have taken the agitator out, but have not been able to remove the cam and agitator dogs (the assembly is listed as #9 on the schematic your site provides). Can you help with this problem. I considered ordering the agitator repair kit or even the agitator assembly (#20 on the schematic).
What parts would you recommend replacing or what steps do you suggest I take? Thanks.
The agitator repair kit should solve this problem. The installation instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSQ9549LQ0 | AppliancePartsPros.com
Agitator dogs - trust washer.pdf (102.2 KB)
