Agitate Problems!
My Washer Will Not Agitate. It Fills With Water Than Stops. I Can Get It To Spin And Drain. Please Can Anyone Help!
Does the motor run when it should agitate?
Gene Thanks Yes The Motor Is Running
Remove the washer cabinet and check the drive coupling (#13 on the diagram). The disassembly instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSQ9200LQ1 | AppliancePartsPros.com
How to remove the washer cabinet.pdf (43.5 KB)
How to remove the pump.pdf (42.3 KB)
How to replace the motor drive coupling.pdf (39.5 KB)
