After running water seeps in bottom
would like to know what causes water to seep in after dishwasher is completely done and not on.
If the water is clean and warm/hot then your water valve is probably not sealing correctly and should be replaced.
I believe the following is the correct valve for your unit.
AP2135535
If the water is soapy/dirty then it could be a problem with the drain hose set-up.
