AFI2538AEW control board won't accept 2012 code for Amana refrigerator
Brand: Amana
Model Number: AFI2538AEW
Main Symptom: new Control Board won’t accept code 2012
What happens & when: won’t accept code during programming stage
Error Code (if any): Beep
Parts or tests already tried: New W10890094 board.
Hi there! On your Amana AFI2538AEW refrigerator, the replacement control board W10890094 needs to be programmed with the refrigerator’s personality code. If the board beeps but won’t accept 2012, there are a couple of things I’d check before assuming the new board is defective.
Try programming the board again
  1. Locate the programming code sticker on the refrigerator’s model/serial number label. Confirm that 2012 is the correct code.
  2. Disconnect power to the refrigerator for about 2 minutes, then reconnect it.
  3. Press and hold the Door Alarm button, then press and hold the Freezer Temperature Down (-) button for approximately 3 seconds.
  4. Release the Door Alarm button and wait for the programming display.
  5. Use the refrigerator and freezer temperature adjustment buttons to enter the four-digit code.
  6. Press and hold the Freezer Temperature Down (-) button to save the code.
The exact button sequence can vary with the control interface, so follow the refrigerator’s tech sheet if its instructions differ.
If the board still won’t accept the code
A beep can indicate that the control received a button press, but it doesn’t necessarily mean the code was accepted.
Check that the display shows all four digits correctly before saving. Also inspect the connections between the dispenser user interface and the main control board.
If the code is correct and the buttons work properly, we may be dealing with an incompatible replacement board or a defective new board.
One question
When you enter 2012, does the display actually show all four digits and then beep when you try to save it, or does it beep while you’re entering the numbers?
That distinction will help us determine whether this is a programming procedure issue or a problem with the replacement control board.
I went through all those steps already but believe I’ve found the answer to the problem. A Amana/Whirlpool tech on Justanswer.com informed me that Whirlpool changed the board to a WPW10310240 with my model with the serial numbers beginning with 12. Mine begins with a 13. He told me this board will accept code 2012 which mine is. He also said the documentation for this wasn’t made readily available at the time the boards were changed. I’ve ordered a replacement board of that number. Once installed, if it works out, I’ll post the results.
The WPW10310240 HV board accepted my 2012 code :slight_smile:
