Hi, my Affinity Washer ATFB6000ES0 started powering on and off by itself to the point I could no longer run a load of laundry. I replaced the main control board. Now washer works but ran 2 cycles of permanent press and at end, both times, laundry laying sopping wet in inch or 2 of water. Ran spin cycle and everything came out dry as it should/drained properly. I had no issues of improper water drainage before the control panel was replaced. So is this a control panel issue or something else (i replaced w/used control board guaranteed tested)? Again, the laundry comes out NOT SOPPING after running on separate spin cycle afterward but shouldn’t have to do this after every load of wash. Help??
Check the drain lines and drain pump for obstruction or problems. If something else were wrong it probably would not work at all or would not finish the cycle.
If they check out you may want to replace the drain pump and see if that fixes things. If you buy from this site and the new pump is not needed you can return it.
