I have an admiral washer that stopped draining and cycling,but the motor humbs.
Hi.
Disassemble the washer and take the drain pump off the motor. See if it’s jammed. disconnect the motor from the transmission lay it on the ground and start without the load.
Check the start capacitor AP6013434
Use the video clip for the instructions AP6010250
Here are the breakdown diagrams and Replacement parts for Maytag ATW4475VQ0 AUTOMATIC WASHER | AppliancePartsPros.com
Simon.
