Admiral Thermostat
I need to find out where the thermostat is located on this frig…most are in the freezer but I dont think this one is…can anyone tell me if it’s located on the back in a panel?? Thanks Melissa
I cannot find any info on the given model number.
Please check it.
If this is not a US model I will not be able to find info.
Do you mean the defrost thermostat or the main control thermostat?
Defrost thermostats are always in the freezer compartment clipped onto the defrost coils.
I have never see a main control thermostat inside the freezer.
If the unit uses an analogue (not electronic) thermostat then it will be behind the knob that controls the temperature setting.
Usually in the console at the top of the fresh food section.
Here is a good site with basic fridge repair help
http://www.applianceaid.com/frig.html
