I have a Admiral dryer I install all new parts in it.It work for one dryer load.Now it only drys when I use time dry on hi or low heat.Does this mean I need a new timer for my dryer?I think all I need is a new timer but I don’t want to buy one unless I know for sure they are not cheap at all.Thanks for any info some could give me on this matter.
So, your saying it doesn’t heat on auto dry cycle? The type of timer on this dryer is a piece of junk and they fail frequently. If you buy from APP you may return it if it doesn’t fix your problem and it has a one year warranty.
Whirlpool W10185972 Timer - AppliancePartsPros.com
Eric
As it has turn out it was my timer all the part’s I put in new was a wast of my money I went out and got a volt meter and check all the part’s I took out and they all check out good and so are the new part’s they all check out good too.So it’s got to be the timer.It’s on order now I’ll up date to let all know how it goes.Best to always check your part’s before you buy.But I did not have the money at the time to get a volt meter now I have one and will check before I buy any part’s at all the timer is not working on all the setting’s.At least I got to clean my dryer out good and see how it is made.Next on my list to do is my washer it has a few part’s I need too but I know they are bad I have check them out and know just what to order.But it will have to wait a while it still works good enough for washing just no spin cycle.
