Hi again Gene,
Checked the wires, romoved the caps and retightend everything, … still the same problem. When it starts (did this time after 7 tries) … will run only in the NORMAL cycle. No high temp wash, that is I can’t engage it to do so, will only run in the “normal cycle” mode.
At least I know it’s getting current. So the level issue is out, the switch issue has been taken care of … only thing left that I can think of is the selection keypad for operating the unit or some kind of a relay.
What do you think? Time for an overhaul? Okay, that’s alright for me but what about the dishwasher!!?
Best (and thanks again)
Paul
